– Instinctive Sailing –
EXCELLENCE CRUISER
You want greater thrills and you want them easily. Performance is simple.
The search for balance is the primary goal of the Dufour 430, 43-foot sailing yacht. An authentic cruiser with exceptional seafaring qualities, it truly embodies the aspiration of Dufour sailing yachts.
Naturally elegant, it stands out with its sleek hull and slightly higher and rounded rear bilge to contrast with its streamlined hull recess.
The deck is perfectly optimised with easy on-board movement and extensive premium equipment.
The Dufour 430, 43-foot sailing yacht is designed for those in search of bigger sensations on the water. It guarantees sensational enjoyment during all your sailing experiences.
13.24 m Overall length
4.30 m Max beam
50 cv (60 cv opt.) Engine power
Smart Elec Pack | Engines | |
Fixed propeller | ||
Battery park (lithium battery) | ||
Generator | ||
Interface monitoring | ||
Options | Improved batteries | |
12V/230V converter | ||
Hydrogeneration | ||
Folding propeller | ||
Quick charger |
Layouts
Berths 8 | Cabins 3 | Heads 2 |
Pullman cabin No | Skipper cabin No | Kitchen Front Galley |
Berths 10 | Cabins 4 | Heads 2 |
Pullman cabin Yes | Skipper cabin No | Kitchen Longitudinal |
Technical specs
Construction
- Architect: Felci Yacht Design
- Year: 2019
- Hull construction: Fiberglass / contact
- Deck construction: injection
Technical specifications
- Overall length 13.24 m
- Waterline length 11.69 m
- Hull length 12.50 m
- Max beam 4.30 m
- Light displacement 9700 kg
- Draft 2.10 m (1.75 m opt.)
- Keel weight 2600
- Fuel tank capacity 250 L
- Water tank capacity 430 L
- Engine power 50 cv (60 cv opt.)
- Sail area 92 m²
- Mainsail 52 m²
- Genoa 40 m²
